I'm getting the following error message on Ad scheduler and I cannot trace the cause of it. Says it "cannot access the file because it is being used by another process".
Looks like some other software has this playlist file opened so Ads Scheduler can't write to it. If you're not sure what software does it, you can try rebooting the PC, maybe this will solve the problem.
