Audio reverb on live mic
V3FM
Hi all,
On my system, music plays out perfectly. Ads and jingles play out perfectly. However, when using the mic we get the program audio "repeating" over the vocals of the mic. This only happens when the mic is live AND music is playing at the same time. When the mic is live and there is NO music playing, it is fine.
Any suggestions?
What RadioBOSS version do you use? Do you hear the problem on your computer (on speakers) or it's in the stream you send over the network?
Hi Dmitry, We are using 5.7.2.0 and it goes out over the stream as well as being heard thru the headphones on our mixing desk.
I seem to have found a work around of the problem by running my host mic in mono ... Not ideal, but it works.
It appears to be the local echo - you hear yourself back, due to buffering a bit later. You can enable the "Output to encoders only" option in the microphone settings in RadioBOSS, or you can use ASIO for both input and output to get rid of latency.
