Automatic advertising replacement.
lughsan
Hello Dimitry, how are you?
I was thinking about adding a system to update ads automatically.
The intention is to update the advertising on a specific date.
current advertising:
Supermarket
advertising update:
Supermarket 03\05\2024
The idea is to perform the file replacement automatically.
Greetings, Dimitri.
You can add two entries into the Ads list and set proper start/end days for them, to have one ad available on certain dates and then switch to another one on different dates.
I understand that, but wouldn't it be more appropriate to create a system where the new audio is input and the system replaces it?
When you add a file with the same name and format, the system performs an automatic replacement.
adding a date and time of the replacement.
Not quite, your task looks like you need to run different ads on different dates, that's why that needs to be configured as separate ads with appropriate date settings.
I'm having errors turning off advertising on a specific date.
When I add the end date, the ads continue to air.
The only way I found is to uncheck this:
What could be happening?
