Aux player
patrick.de-bruyn
I have a question about the AUX input.
I have a virtual soundcard where I have configured the telephone (Sipgate) with the FritzBox.
How can I send the AUX input to the stream?
Patrick if you have the virtual sound card plugged in it should have loaded a driver for it check in control panel. If this is resident it should also appear in windows mixer as an output, you should then be able to place it in RB >> Settings >> there to playback to send aux to it. If you want to input from this, you change it on RB >> Settings >> Input, then press change line in to set it to your card. I did some experimenting with this before. Pressing soundcard should show the input too.
For example,
but there is no possibility to insert a line in into the aux player
it worked for me Patrick its a fudge. You have to tick microphone on, but it worked ok. before I bought a separate mixer my Mackie outputs into my Focusrite doing A to D which I love now have mics and lines in that and out to the mic lines, but it needs to be turned on all the time It should come up with an option if the drivers are loaded in windows.
