command or process
radium98
Dimitry can you please indicate me where i can find or the name of the process or the command line in window 7 (32/64) bit that is responsable of the window reboot please ,because i need to make a task to reboot the pc in xx days ,i know RB can do it and i used it as this but i need to know the process loaction and name
thanks .
The reboot command in RadioBOSS does not use external processes - it calls Windows API function to do the task.
There is shutdown command in Windows that you can use to manually reboot, log out etc.
