delete played
flopyplus
Hello. I see that the played items no are deleted when in queue mode. The "repeat" mode affect this? What is the reason?
Thanks, sorry for my english and regards.
Yes, if repeat is enabled, the tracks will not be deleted. Because if track is deleted, it can't be repeated.
ok, but if the last ?tem load a new playlist? after hous or days, the list is very very long is nothing is deleted.
Edit: in other words.. Is possible load a new playlist in the main playlist that delete the actual (like in others softs)?
If you use the scheduler, you can clear the playlist window before loading a new playlist - use the "Clear playlist" option.
