Edit event after being executed
lughsan
Hello Dimitry, how are you?
I've been trying different ways to program RB and was thinking about the following idea.
It would be helpful to create a smart playlist that can be updated at any time.
especially if for various reasons an event is executed early and left in a queue.
It would also be of great help if an ad unit that is already queued needs to be updated.
Greetings, Dimitri.
For example:
An ad unit event runs at "10:30" and is queued.
If I need to update the block immediately it is not possible, since the tracks are already in the playlist.
Will it be possible to create a smart playlist that can be updated externally from notepad or m3u list?
Why not? You can edit the playlist directly, in the playlist window.
Do you want to control it from the remote computer?
It is possible, but you have to intervene in the program.
I mean doing it externally from the same PC.
Would it be possible to do it from an m3u list?
The intention is to create an update alternative, and avoid bothering the person who works in RB.
