Good morning. I have a very serious problem with Radioboss, which closes the program and prevents it from bringing a new playlist to the playback window.
It generates the following error: Access violation at address 00A300DA in module 'radioboss.exe'. Read of address 0000005C.
It happens whenever the programmer executes the following:
Clear active playlist
run a playlist of about 4 station ID files (end of the current program, stationID and start of the next program) (The programmer should then continue generating another playlist)
but when he has the playlist files requested by the programmer, Radioboss closes and restarts, continuing the previous playlist that was already in the window.
Can you help me with this case?
What could be happening?
What should I do?
Thanks!
What should I do?
Thanks!
