Error Running Radioboss Newest Version On Windows 7 Need Help??
DJboutit
I am running the newest version of RadiobBoss x86 version on Windows 7 after 30min to 2hrs I get this error the crashes the program on a Windows 11 computer the program runs just fine. Here is the error I getting
I having trouble with one program I ran it on Windows 11 without any problems currently I am running this same program on Windows 7 and I am getting this error
Exception code: 0x0eedfade
Fault offset: 0x0000c5af
Faulting process id: 0x10e0
Faulting application start time: 0x01db1a8e56371d94
Faulting application path: C:\Program Files (x86)\RadioBOSS\radioboss.exe
Faulting module path: C:\Windows\syswow64\KERNELBASE.dll
What does this mean and how do I fix it??
Does this error mean I need to upgrade to Windows 10 if not what does it mean??
If you use any 3rd party plugins, please try disabling them. Update all drivers to the latest versions. RadioBOSS should work fine on Windows 7, I don't think operating system is the problem.
