Hallo, it would be nice, if the Silence detector was able not only to play a specific Playlist. Maybe it would be great, if there was a way to set commands like "getrandoomplaylist" or a relay command usw
Yours
Jörg
Creating a playlist will take some time, so it won't really work in an emergency case when the Silence Detector needs playlist immediately to fix the silence.
You can make Silence Detector play some playlist, and also create a scheduled event that will run like 1 time a day, every day - the event will run the playlist generator to update the silence playlist.
