Extended Logs for Playlist Generator Pro (PIGenerator Pro)
Altec
Hi Dmitri, Hi Djsoft Team,
I'm using regularly priorities additional rules in RB, and there is an amount of tracks excluded by the Playlist Generator following the established rules. I wanted to ask you to create an "advanced log" or an "extended log" for playlist generator to be able to visualize what the random motor selection is doing and what titles are excluded or not to adjust my rules and have a rich and equilibrated program.
Thanks in advance
Altec
You can find the extended log in the folder: in RadioBOSS, click Settings, Open Settings Folder, then open Log folder.
I found the playlistgenerator.log but as I told you there is no details for example about the excluded tracks, we can't know which track are exluded :
Example :
[2025-01-31 20:56:39] Tracks excluded (priority less than zero): 5
Ty
Altec
