« Fade in » - Very loud volume
Guillaume
I notice that the volume between the “Start” mix point and the “Fade in” mix point is very loud when a track is played in the playlist player.
The sound saturates between these two mix points when the title plays in the playlist. The sound is correct in the “Track Tool”: the “fade in” works but not in the playlist player.
I had this problem on version 7.0.7.0 and also on the latest version 7.0.8.0.
I only just noticed this because I have few tracks that use this “Fade in” mix point.
It should be exactly zero at Start and gradually increase to 100% when it reaches the Fade In point. The path how it goes 0-100 depends on Settings/Playback/Crossfade curve setting in RadioBOSS.
