How to Create a "Harmonic Preset", using the "Comments" Tag ...
RebootFM.com
I'm pretty sure there's an easier way to create a "Harmonic" preset utilizing the "Comments" tag, if possible.
As shown below, I've already arranged my music library to reflect the ENERGY Levels of the music according to their Rating (4, 7 etc.), BUT I really need to know how to setup a TAG to arrange the music by Harmonic Level (10A, 3B etc.), as depicted in the Comments Tag??
Although greatly appreciated, kindly and respectfully do not refer me to the (Tags Link) in the Help window. I sometimes find the instructions a bit confusing, or not as thorough in it's provided example ...
Please note that filtering using the Comment tag is a legacy feature, that was added couple of decades ago. Now it's much more flexible and easier to use the Tags: https://manual.djsoft.net/radioboss/en/using-tags.htm
It allows more filtering options, as well as batch assign/remove tags for groups of tracks.
Can you please be more specific at what's not working with the Tags feature? Tags can be assigned in batch/individually via the Music Library, and also using Track Tool or tag editor under the playlist window.
Do not use comment field at all.
