davidbcn1970
When I configure a line input, I have to specify that it is stereo, by checking a box, when the usual thing is that the line input is stereo. If I forget to check the stereo box, the audio goes into mono, and that has several problems: if the channels are inverted, they cancel each other out and nothing comes in. If the channels enter with unequal signal level, the audio is attenuated.
My request is that the line inputs be considered stereo by default, and if you want (or someone considers it necessary) the box that has to be checked is "mono".
That is, it works just the opposite as before.
