Load an internet streaming
Don
How can I put as https:/ to work on RadioBoss ? I can It seems that it can only play http:// streams. Any solution?
Both https:// and http:// are supported, no special action is required, just input the URL.
Unfortunatly not. It just does not play HTTPS:// streams. Message: Unable to play! Error code 2... - Works 100% with HTTP:// streams, but most streams are https at present
Error code 2 means it can't connect, probably some problem with the server. I did a quick test with couple of https:// streams and they played fine here.
You can provide us with your stream URL to test (write to support@djsoft.net if you don't want to post it on forums).
often http streams have a different port than the https stream from the same radio e.g. 8005 for https and 8000 for https
