chrismadog
Hi everyone,
We have a problem when we moved studio locations.
PCs have the following specs.
8GB RAM
1TB SSD Drive
Windows 11
RadioBoss 6.2.2.0
The output level is way down.
I have checked all the settings, including the sound settings.
As well as this and to compound the problem, any track with 100% volume level will result in quite audible pops or crackles as it peaks. Dropping the level to 90% using MP3Gain fixes it, but as I said, that compounds the problem.
I installed another playout software package (*removed*) and it is way louder than RadioBoss and does not click, pop or crackle. This is not the fix wanted - we want RadioBoss !
But, it does demonstrate the two problems descrobed - Low level and clicking/popping/crackling. The difference in levels between RadioBoss and *removed* is dramatic - at least 10db difference. Yes, that's right - at least -10dB with RadioBoss.
I've gone into all the settings. Nothing fixes it.
Any help appreciated.
ChrisM
Station Engineer
Rose City FM
Warwick, Qld, Oz
8GB RAM
1TB SSD Drive
Windows 11
RadioBoss 6.2.2.0
ChrisM
Station Engineer
Rose City FM
Warwick, Qld, Oz
