DJ Chris
Hi Everyone,
Is anyone else having the problem which I have had now for several days as I can't seem to shift it, it's not showing the current playing track artwork it only shows the default, as the one you put in place as your station logo.
Now I have been all around the houses as I haven't made any adjustments so I'v done the following, cleared cache on PC, re-added the widget, and checked all the settings with still no luck.
Has anybody got any extra ideas to try????
Thanks in advance
DJ Chris.
Thanks in advance
DJ Chris.
