Pausing Playlist Items for Live Stream
VBRadio
Hi. I have searched for an answer to this but it wasn't immediately apparent. Is there a way to have a long play file (DJ mix) that is part of a daily scheduled playlist PAUSE when a Live DJ takes over, so that the mix continues off from where it was interrupted? At the moment, the song continues to play in the background? /
Thanks in advnce.
I'm sorry but such a feature doesn't exist in RadioBOSS. If you know when the DJ is going to connect/disconnect, you can create the scheduled events to pause and unpause the playlist.
Thank you for your prompt reply. This probably creates a lot more work than is necessary, seeing as there will be so many instances throughout the week it would need to be implemented.. Is it possible to request that this pause/unpause feature be considered in future updates?
