playlist folders
mikenico
what would be nice is to be able to have a two fold pane views between two  playlist folders showing then and be able to drag between two and from.
if that makes any sence
You can already do so: activate Work Zone 2 or 3 (View->Work zones) - you can create AUX playlists there. Tracks can be dragged between the playlists.
Doesn't work...
Doesn't work...
Can you please be more specific?
Simply. I cannot drag tracks between playlists. It just doesn't work. I can make a movie :)
You need to start dragging by track number. Please see this page: http://manual.djsoft.net/radioboss/en/playlist_window2.htm
I put "play" icon after the number of the track. That's why didn't work.
Yes, it works. Not smooth, but works.
Yes, the Play icon can be an issue here... This will be improved in the future.
