playlist problems
DJ_Ferdy
I get this message after I have loaded the folder with music. Do I restart the program after an update or something like that, is my music all gone and do I have to load everything again? I just did a clean windows 10/11 install and I still have this problem?
You need to close RadioBOSS when installing an update - otherwise it will not be possible to install it. The errors mean that the playlist file for the profile (the playlist tabs) can not be loaded for some reason, e.g the files could be damaged or locked by other software.
