Jörg B
I already had this issue with the beta version, but the error has not been fixed. My server is currently still running version 7.0.8.0, because even the final version 7.1.1.4 causes an error when generating certain playlists via the scheduler. However, this issue really only occurs under 7.1, not under 7.0.8.0.
One example is my regional news playlist. RadioBOSS is supposed to generate a playlist at specific times containing the following elements:
A music bed runs underneath it, and the news segments are marked as voicetracks. I created a preset for this in the Playlist Generator. Under both 7.0.8.0 using the scheduler and 7.1.1.4 when manually clicking “Generate” in the Playlist Generator, the playlist is generated correctly, and I can then load or play it as a playlist.
However, if I try to start the event with the preset via the scheduler under 7.1.1.4, I get the following error:
"Playlistgen Error Preset =Regionews"
The same applies to my event announcements, which are planned in a similar way. As mentioned, everything still works without any problems under 7.0.8.0.
- Opener
- First news
- Transition sound
- Second news
- Transition sound
- Third news
- Closer
