hola soy nuevo y estoy iniciandome con mi radio por streaming, tengo un problema que no logro resolver, el radioboss transmite pero en el servidor va como 20 segundos mas tarde, igual cuando hablo yo. A que puede suceder?
you always have to reckon with latencies
until your music arrives at the server, is processed there and forwarded to the listener takes time
also with which bitrate (Hz) your stream is operated, the higher the less latency
