Radio boss is not opening report window handle is not valid
Anfelch
Please help I'm getting the same message over and over and radio boss will not start if open as an administrator i get FMRB and radio Boss wouldn't show anything. What is causing the issue and how can i fix it. Please
Can you please specify what does the error message say? You should not run RadioBOSS with administrator rights, those are not needed and it's designed to run with user rights anyway. Probably you can try reinstalling it.
I saw some other users had the same problem.
Do you get the same error messages or yours are different? Please ensure that you have the latest RadioBOSS version.
