Peter Tate
Hi Guys,
I've got Radio Boss itself working perfectly in a VPS environment. I'm wondering why the Virtual Audio Cables don't show up as an option in the main soundcard settings?
I use Breakaway for audio processing. I know RB supports plugins and others can be used within RB etc. But you really want Breakaway on the job. You install the Virtual cables and everything else sees them except Radio Boss. This is a VPS don't forget and there is technically no soundcard devices in the true sense.
My initial thought was maybe it appears to the registry that there is no soundcards, so no need to load drivers. But why does Breakaway see them and RB doesn't?
I've got a workaround in place using the internal streaming server. But I'd rather use Virtual Cables or Pipes so the audio quality is top notch.
Any suggestions folks?
Cheers All
Cheers All
