RadioBoss and RodeCaster Pro 2
mondoman2k
Does anyone use a RodeCaster Pro 2 with RadioBoss? How you configure your inputs from RadioBoss such as PFL, Monitor, Playback, Cartwall, etc into channels on the RodeCaster? Also, do you use the RodeCaster (a separate mix minus channel?) for voice tracking in RadioBoss? If so, how did you configure the setup of the RodeCaster and RadioBoss.
Thank you for any insight you can provide. I used a Heath & Allen XB 14-2 for many years with RadioBoss and was able to use a separate audition bus for voice tracking. I'd like to be able to use all the capabilities of the RodeCaster Pro 2 with RadioBoss if possible. I guess the Duo could also work in most cases, does anyone use the Duo?
