Radioboss every 24 to 48 hrs the program keeps freezing I have no idea why I have to restart the program to get to work again and half the setting are gone.
There's an error on startup - failed to load settings. It means that RadioBOSS can't read the settings file for some reason. You should fix this problem e.g. check folder permissions, or maybe antivirus blocks the file operation.
Actually, it can, inability to read settings is a serious problem, it means other files also can be inaccessible or corrupted, this makes program behave in unpredictable way. You need to fix it, e.g. try reinstalling RadioBOSS to a different folder.
