RadioCaster Question
I run radioboss cloud and the express version when I go live using radiocaster to switch to live from the cloud. Is there any way for radiocaster to automatically engage and connect? I have Radioboss Express set to load playlist and go at 6am, but I have to be around to click the mouse on radiocaster to go live. Would be nice if there was a setting to just switch over at that time.
You can upgrade RadioBOSS to Standard edition and broadcast from it directly, you can enable and disable live stream using the scheduler.
