malejandrodev
I've been using radioboss since 2018 (5.7.2.0) non-stop. At first, when loading playlists of material, playback was immediate, but as time went by this became slower. It took 1 second to play the first material. Currently, it sometimes takes up to 3 seconds, generating up to 90% CPU usage. Is it possible that there is some parameter that slows down the start? For example, the playback count? I have deleted log files and others but it does not make a difference. Is there anything that can be done? I have no problems with RAM usage or hard drive access speed.
I also have high priority enabled for the process.
For example, after the command execution, a call to an m3u file containing some playback materials follows (a few, no more than 15).
