Right click and copy
Viafiber.se
As usual, I reserve the right to have missed something in the manual, and with that said, here comes my request:
When I have created a scheduled task/event that I want to implement on another or several installations of radioBOSS that are on the same server, it would be nice to be able to right-click and copy this scheduled task/event, and then paste it into another installation of radioBOSS.
You can do it via Export/Import feature. Use the List button under the events list, then click Save selected - it will save the selected event(s) to a file. Then you can use List->Import command to add events from that file on another instances.
