Hi,
When saving a playlist with the same name as an existing one, there should be a warning prompt to confirm whether you want to replace the existing file. However, in the current situation, the warning prompt is missing, and it directly overwrites the existing playlist without any warning. The same issue also occurs when saving presets under the playlist generator pro.
