The scheduler commands to create the daily playlists for the shows did not run. They are not marked do not run if playlist is stopped, nor is this selected in global settings. Therefore, the weekend shows did not run (no playlist). I checked for error messages, there were none. I created the playlists from the generator and loaded them in the player.
I updated the program on 8/30 using the in program update command. I wonder if the patch was not there at that time? I rolled back to 7.0.5 last night and everything seems to be ok.
