Stream audio after Breakaway Audio Enhancer.
Mihalis81
my Radioboss setup and Breakaway is the following :
Radioboss
Μain on air soundcard - (DS)Line 1 Breakaway pipeline
Monitor Soundcard - (DS ) Speakers
Breakaway audio setup
Input - (KS) Breakaway pipeline 1
Output - (DS) Speakers
PC Sound
Playback - Line 1 Breakaway pipeline
Recordings - Mic
It looks that breakaway works fine.
the problem is that when i bypass breakaway i dont hear anything changes.
So i Think that the output of breakaway compressor is not my stream audio out.
Can you pls help me what i am doing wrong?
Thank you!
Can you pls tell me why i cant add winamp DSP plugins dsp_livelink1.dll - dsp_livelink.dll in radioboss v.6.3.3.0 when i already have copied them in the folder c:\Program Files\Radioboss \ Plugins\ ??
thank you very much
Sorry for the previous question. I have found the solution.
I have the steps that youtold me :
You should configure one of the Linear Inputs in RadioBOSS to use Breakaway pipeline device:
https://manual.djsoft.net/radioboss/en/microphone___line-in.htm
Then in Broadcasting section, select Source to use that line input:
Settings > Broadcast
This way, you will hear processed audio in the streaming.
I put in input 1 (Line in) - DS Line 1 Breakaway pipeline
and then in broadcast i have select source : input 1
and then the music from stream stops and i have the message DS : Unable to start the...
where is the wrong i am doing.
Thank you
You need to use a 32-bit RadioBOSS edition in order to use Winamp plugins. They will not work in a 64-bit RadioBOSS installation. Please see this guide about using the plugins: https://www.djsoft.net/community/threads/using-winamp-dsp-plugins-in-radioboss.3480/
The error message says "the device is busy" which looks like another software is already using the device in Exclusive mode so no other software is allowed to use it. Please also check if you don't have Exclusive mode enabled in RadioBOSS too (in both Playback and Input settings).
thank you very much
You can, make sure both are 64bit as well as Windows, be just not using it within the plugin's ability Dmitri said try and drive it from a line out of RB I think.
