Teasers - 'Too few upcoming tracks' code 902 error
box26609
I'm having a problem creating teasers when I select 'up coming tracks' as my source. I constantly receive the error code 902 (too few upcoming tracks) - and the teaser ends up blank -yet my playlists will typically have more than 20 songs. When I select a music folder has my source I don't get this problem. What could be the cause of this and how do I rectify it?
Settings used:
Tracks - > Coming up next (selected)
Max tracks to look ahead - > 3
Track count - > 3 - > shuffle tracks (selected)
AutoHook for tracks without hook points-> (selected)
Still I get the error code 902
In this case, it only checks the three following tracks, and if some of them can't be used for a teaser (e.g. it's a jingle, or command or something else) you will see the error.
I think to resolve this error, you should make it look ahead a bit far, e.g. 10 tracks.
I've tried that. I get the same error unfortunately. I have the latest version of radioboss installed.
Even when I insert the teaser in a playlist with 585 songs with no jingles or commands, I still get the same error
In the Teaser window click the Settings button and check what tracks are excluded. There are filters by duration and it can also exclude file types, maybe those are configured i such a way that no tracks can be selected.
