jharris171185
So I have added several folders to my music library. In total, we're talking about like 6500 tracks, which is a LOT of music. However, I've noticed that while all files from the first two smaller folders get added just fine, and in the music library itself the bigger folder seems to get added, but then in the search tab, not all of the songs show up. Is there a limit to how many songs can show in the results? This is when nothing is typed in the search box, and I am just scrolling through whatever shows up there. I often do this when looking for inspiration, trying to find something I maybe haven't played in a while.
In addition to not everything showing up in the search window, sometimes I will go to insert a track in the playlist, and it won't be inserted. But, then I go to the file explorer and insert from there, and it works. So, it definitely seems like something is off.
Lastly, it also seems that once every few days, I go to search the music library, only to discover it was somehow wiped blank. Adding things back is easy enough, but it is enough to indicate that something is probably wrong.
I don't think it's a software problem, but could easilly be that I'm not doing something right. Any help is much appreciated.
