Using the F-keys?
Viafiber.se
Maybe it's just me misunderstanding, but I thought there would be a 'popup' when using the F-keys (see the video). Am I blind, or have I missed something else important in the manual? Perhaps trivial, but we chose not to use the 'left panel' to be able to have more radioBOSS on the server desktop.
Well, I am, but I've found that if the panel is visible the F Keys work. I think a compromise would be to make the panel visible if one of the f keys are pressed and for the focus of the cursor move to the first edit field or item in a list. This way, for example, you could press f2 from anywhere in the main radioboss window and begin typing.
I guess it would be logical to show the left panel if it was hidden, and then activate the requested section. This is the intention of pressing those keys. The change will be made in the next minor update.
