Web Port Link vs Direct link
  • Thread starter Thread starter markhamil94
  • Start date Start date
M
markhamil94
Guest
Hi - as a new user to the RadioBoss cloud, can someone explain the difference between Web Port Links and the direct streaming address? When should I use each?
The difference is the port used to serve the stream. Sometimes non-standard ports are blocked by network administrator (e.g. corporate environment) so the stream is only accessible via a Web port (80) and will not work with the ports the server work on (e.g. port 18015).
