Radiologger question and a suggestion for improvement
patrick.de-bruyn
i have a question about the radiologger
You have the option of separating the recordings into a maximum of 60 minute segments, which is actually too little as most broadcasts in Germany last over 2 hours
a selection up to a maximum of 999 minutes, for example, would be better
Many radio stations also have several different streams, for example a rock and an oldies stream.
How could you manage this, can you start or install the radio logger several times with the same key?
We'll consider that for the future updates, thank you!
Just in case anyone else is interested: it's possible, you need to install RadioLogger multiple times into different folders, and configure each instance separately.
Is there any news for it?
You can disable record splitting if you want continuous recording. An option for extended record split duration is still on our to-do list.
