Running events early
derek
It would be ideal if a flexible time option were available as part of the options for what could be used as a sweeper. If this were used, radioboss could run an event early, with no extra additions or changes needed to the playlist. This could also be useful to keep radioboss on track if it is dealing with a series of playlists that run a bit long. At present, what happens if the sweeper option is checked, but no files added as possibilities?
I think this can be achieved if you set event's start time a bit early.
It can, and there is some help if I have the ID event finish at the top of the hour. That still allows a song to begin between the end of a track and the beginning of the ID, and that can throw off the start of a relay.
I thought of this suggestion hoping that it would be easy to to do, given how sweepers work, and that it would also be something you and others would consider practical.
Sweepers is the solution for this. I don't see how "start earlier" will work, I mean what's the difference between the event that's supposed to run at e.g. 12:00 and with has option like "allow to start 5 minutes earlier" and an event that simply configured to start at 11:55.
Radioboss would be able to run the event early only if it were necessary. Consider the following scenario.
15 seconds are left of the currently running track and no sweepers are available to fill that gap. Radio boss could run the event early so the next song on the playlist wouldn't make everything run behind.
Also, when we have generated multiple playlists, radioboss could stick to those playlists without introducing random elements at the last minute.
Just bumping this thread because its been 6 months, and we just had a playlist end at 12:59:59. Sense I didn't have a sweeper that was 1 second long, a sweeper was added which actually delayed the ID at the top of the hour. It was only delayed by 20 seconds, and considering we were not cutting to something that was live at that point, it wasn't a big deal. If we had the flexible time option, and if I would have allowed a window of a few seconds things would be even better than they already are.
Makes sense. We'll need to run some tests about it here. If everything's good, it'll be added as an option for the events.
With the vastly improved options for filling time between the revamp of how sweepers work, and with the option to have radioboss change the duration of the track chosen for the bottom of the hour, this feature as I described it is as important to me as it once was. However, it would be great to have this exist in a different form. This feature would allow a scheduled event to start early if the time remaining between the end of the current playlist track and the scheduled start of the event is too short to justify playing a sweeper or filler track.
Specifically, the idea is to let users define a minimum time gap threshold. If the available time between the end of the current track and the scheduled event is less than this user-defined value, the system would automatically skip the scheduled sweeper and trigger the event immediately.
I tried to edit this post, but was too late. What I was going to say in that edit is that the "Minimum time to sweep" option comes close. From the manual: "if less than the specified number of seconds remaining until the end of the track, do not insert the sweeper and allow it to cut the end of the track." In stead of cutting, just run the event early. Cutting the track would make sense only if the "Run scheduled launch without waiting for current track to finish" box is checked.
