Scheduled spots repeat in playlist if an error occurs
brockl
I have had several times that a spot repeats in the playlist due to the music rotation playlist not loading correctly.
Is there a way to have this not happen and the auxiliary playlist load and play? The aux playlist loads correctly if the playlist just runs short.
What is going on if the scheduler runs playlist and saves it with player=xxxxx ? This causes the playlist to not be recognized and doesn't play.
Can you please provide more details on what happens?
Scheduler usually does not save anything. I guess more information is needed on this too.
Walked back versions, same problem with 7.0.6.0. 7.0.5.0 is working and creating the auto generated playlists without player=5xxxxxx. Version 7.0.6.0 did the same thing wrong, however the file ended with player=4xxxxx. Hope this helps diagnose the problem. I am creating the playlists a day ahead with a filename mask for date and the +1d modifier. Creating the playlists manually works fine in 7.0.8.0.
the auto generated playlist was named Playlist A2024-10-30 -Player=527158, I renamed to upload it here
The playlist file is OK, what happens when you load it into RadioBOSS? What if you load it manually using the Open command in RadioBOSS?
Looks like the playlist creation command is wrong. Please share what command do you use to create the playlists.
run PlaylistGeneratorPro.exe "-preset=Smooth" "-out=R:\RadioBoss\Playlists\Playlist A?yyyy-?mm-?dd.m3u8?+1d
The command will create a playlist and those playlists are seen in the folder; also you have sent the contents of one of those playlists and there are tracks. Can you please specify what's wrong?
