I am having a new playlist repeat more often with an event setting.
I would like to have a jingle (Top 30 jingle) played first before the playlist starts.
If this doesn't work, could someone share their settings?
You can include the jingle in the playlist itself, or add it as a first action in the event actions.
Jingle can be a fixed file, or you can use a Track List feature to select a random jingle from a folder: https://manual.djsoft.net/radioboss/en/using_track_list.htm
you could do that with auto intro
set a tag for the first title, for example Intro and do it like in the picture
a jingle is played before the first track
das könntest du machen mit auto intro
setze für den ersten titel ein tag beispielsweise Intro und mache es wie im bild
so wird vor den ersten titel einen jingle gespielt
