Question about auto intro
It means that from 7.1 AutoIntro will have its own settings, so how many dB should it lower the music when it is running and fade in/out and other parameters?
Yes, there's a separate configuration section for this.
I would also make sure to have it read the mix points of some audio files that you want to use on AutoIntro, because some users need them.
For Auto Intro, it only reads the Playback Level tag. Mixing and other points are for playlist.
could the graphic aspect of when AutoIntro is running be improved?
and also a "stop" button if for example it starts on a song and we stupidly don't want it, maybe because we are live and we want to talk over the intro.
Or if you fast forward the song, auto intro continues on its own and it's not nice.
We'll see what can be done there, thank you for the suggestion.
I have another question about voicetracks: I notice that when songs with voicetrack air, the mixpoints aren't correct - i have mixpoint set in general settings, not in track itself. It is almost like RB plays the song full to the "end" point. Is this purpose? (7.0.8.0)
