Adding CART and Auto Intro bypass to DSP so that compression is not applied or other DSP Effects
HMMMM
Can you tell m if it is possible to Add something to the Radio Boss CART and Auto Intro bypass to DSP so that compression is not applied or other DSP Effects. I notice these might be able to come out on monitor, but can you get that to bypass DSP. There is nothing in the manual about voice or MIC to bypass this
Thanks for looking?
This is planned for the next major version (because it will require a lot of internal work). Currently, to bypass DSP for cart wall, you can set its output to other device (not main card).
I don't think it's a lot of work can't you cut copy code sections you already have for cart and jingles? This would be ensuring your great beta releases?
