PAULO ROBERTO
OK
WITH THIS COMMAND UPDATE THE BLOCKS...adsupdateexcellent.
Surprised by the versatility of "RB"
I just found a way to do it.
The only problem I see at the moment is the trading block update.
if a "PGP" list is executed, there is no way to immediately update the business block it contains.
In that aspect I think a "command" would be the most appropriate.
For example:
rock music block
sweeper Radio
rock music block
Jingle radio.
rock music block
runadvertising.command=30 (advertising block)
metal music block
Jingle radio
metal music block
sweeper radio
metal music block
The idea is to be able to update the trading block at any time.
If we manage to do this, it will be possible to update the trading block before it starts.
hello Paulo.WITH THIS COMMAND UPDATE THE BLOCKS...adsupdate
In this case you need to create playlist again, it will take into account updated ads playlists.if a "PGP" list is executed, there is no way to immediately update the business block it contains.
adsupdate command must be run separately, before creating a playlist.How should I do it, I try but it doesn't work for me.
There is no way to update when you are already inside the playlist.In this case you need to create playlist again, it will take into account updated ads playlists.
It is doable but it can be improved.I don't think a new command is needed because it's already doable with existing features.
Ok.adsupdate command must be run separately, before creating a playlist.
You should update ads playlists first, then generate music playlist that will insert already updated ads playlists.There is no way to update when you are already inside the playlist.
Let me explain if I run a "PGP" list of one hour duration and within it I have 2 trading blocks, the system does not allow me to update them instantly.
You can schedule adsupdate events more often. It won't hurt.It is doable but it can be improved.
it is necessary to be able to update a trading block at any time.
we should not wait for the next event for the ad units to be updated.
That's right, that would be the closest solution.You should update ads playlists first, then generate music playlist that will insert already updated ads playlists.
what would be the correct way to do it?You can schedule adsupdate events more often. It won't hurt.
If PGP references ads playlists in its categories, you need to ensure the playlists are updated before you create music playlist.The idea would be to update the commercial block, which is inside "PGP".
You should run the ads using the scheduler, this way they will start when needed.I'm adding a full listing during certain hours and can't adjust the ad times.
How could I better calculate times?
This is a known issue, and will be fixed in one of the next update.Is it possible to delete comments as the playlist progresses?
I already did it this way, but unfortunately it destroys the structure of the previous event.You should run the ads using the scheduler, this way they will start when needed.
excellent.This is a known issue, and will be fixed in one of the next update.
Looks like you should use the "Overlay playback" option: https://manual.djsoft.net/radioboss/en/eventoptions2.htmalready did it this way, but unfortunately it destroys the structure of the previous event.
and even if you queue the event, the timings still fail.
I think a more practical solution would be to create a smart list, where events have set times.
while music, jingles, etc. They remain in the background but without losing the structure.
It's a good alternative, but I think you can do something better.Looks like you should use the "Overlay playback" option: https://manual.djsoft.net/radioboss/en/eventoptions2.htm
I'm not sure I understand what you mean.It's a good alternative, but I think you can do something better.
