I would like to use
within playlists to be able to switch between several playlists.
In itself it would work if there wasn't a problem.
I have set that played elements should be removed from the playlist. This also works with normal songs or jingles, but not with the command.
Example:
Playlist1:
Track1
Track2
(Command) playlist Playlist2
Track3
Track4
Playlist2:
Track1
Track2
(Command) playlist Playlist1
The tracks played are removed from the playlist. At some point, "(Command) playlist Playlist2" appears and the playlist is changed. Then Track1, Track2 and "(Command) playlist Playlist1" are played. The system switches to Playlist1, but the command is still at the top because it is not removed.
There is a continuous loop between the two commands until the silence sensor intervenes.
I hope I was able to explain the error reasonably well.
If anything is unclear, I can make a short video if necessary.
Christmas greetings
I would like to use
Code:
(Command) playlist {NAME}
Example:
Playlist1:
Track1
Track2
Track3
Track4
Playlist2:
Track1
Track2
Christmas greetings
