Hi there,
Could you please add the option to use Tags to create "do not repeat" rules? Currently it's only possible to completely filter by Tag, not just seperate.
Background info:
I run a non-stop music station with hand-mixed (one hour) shows of dance music. I'm using the Playlist Generator PRO to create random playlists with separation ("do not repeat" rules). To identify tracks I use from other shows I use tags. Example Show number 1001 has tag 1001. If Show number 1035 has tracks from 1001, I will add that tag. So Show number 1035 has tags: 1001, 1035. I would like to have the no-repeat rules to look at tags. So in this case Episode 1001 and 1035 will be seperated by a few hours.
Hope you understand and can make it work
It gives a lot of new options to the "do not repeat" function.
Thanks in advance.
Background info:
Thanks in advance.
