Help for backup
topmaiswebradio
One made a backup of database and settings, if I format the pc and reinstall radioboss, will I have all the settings restored, including all the programmer's schedules?
Yes, if you have backed up the database and settings properly, you should be able to restore all your configurations, including the scheduler events, after reinstalling RadioBOSS. However, make sure to save the backup on an external drive or cloud storage before formatting your PC.
To restore, reinstall RadioBOSS, then replace the new database and settings files with your backup. It's also a good idea to double-check the backup files to ensure they include all necessary configurations before proceeding with the format.
It's always best to wait for an official response from the RadioBOSS support team to confirm the exact steps and ensure nothing is overlooked.
