Highlight row
I really have a lot of problems with the highlighted row.
In Windows XP it looks very, very ugly and it makes impossible to see the track name.
Can you make a brightest highlighter row?
Maybe when track is highlighted, its colour to be transformed in white. After track was played its colour to be as its type.
Thanks !
The text will turn white if you select a regular (e.g. non file type) track in the playlsit. For file types it preserves the color.
Currently it's using the windows system color to mark the selection - you can change it: right-click on desktop, select Properties, the setting is located somewhere in Appearance (IIRC).
A setting to change selection color in RadioBOSS can also be added.
