How can I make a clean cut for the jingle transition ?
madein80
I would like certain jingles to follow quickly after the previous song, starting right at the mix point.
I've set the fade-in to zero in the crossfade settings for this file type, but I'm still getting a long fade-out (from the mix point to the end of the song) on the jingle.
How can I make a clean cut for the transition?
Looks like you have "Start fading out on mix" option turned on for jingles file type.
