I do not know if this is possible but it would be nice to add a real playlist scheduling system and a stretch.
Let me explain :
For programming the playlist it would be cool to have the same system as WinMedia. This means creating playlists for every hour of every day from the playlist generator. Then generate the musical programming for the week for example and be able to access hour by hour and day by day by a calendar.
Add an auto stretch. It would be good at the beginning of each hour to define if we want an event that will start at 00:00: 00 thanks to stretch music will be accelerated or slowed down to arrive at the right time and end on a late music. If there is not enough music then an automatic fill would be added to arrive at the correct time
It would also be good to add a total configuration of the cartwall. Actually we must do CTRL or SHIFT wait and press what is written on the cart. It's long and it's not practical. it would really be able to just assign the key you want without via the cartwall settings
Let me explain :
