Peter Tate
Hi Guys
I've created short 2 item playlists that have a Voice Grabb of an Artist then the second item is one of their songs. So it sounds like they are endorsing the station.
Example - Hi this is Janet Jackson and you are listening to me on XX -
Then it plays one of her songs - like Black Cat.
Because an Artist like Janet has many tracks in rotation there are something like 6 playlists with the same Hi This is - but with different songs. They labelled - Janet 01.m3u and so on.
For the life of me I can't get these to work inside a Rotation (or clock to alot of us). I've tried every tab available in the section where you point to your files. After you have created the Category. You go to Tracks and it gives you the options... Folder | Track | Playlist. I point to the Folder and think it will pick.... Nope nothing. Track - is no good nothing happens either. Playlist - no matter what i do it only load the Id and not the song. So I think..... can I put these into My Libray as single items.... then point to library. Nope!
I do get this to work by using Insert Playlist as a scheduled event. But this has no respect to the position the playlist is in when it is time. I'd like to get this all done inside the Rotation (aka clock) please. So I can control the exact order of events around the hour. Some things must follow the correct item. Example - I use Bumpers to go in and out of a spot break. You dont want this pushing in if the spot break is running late.
Suggestions please... cheers all
